vdubb16
Ive got 58ft of Rohn 25 currently with a A-99 ontop. Id like to put a beam up again, probably another maco Yquad. The last one i had up was on a rotor with a 5 ft mast that the antenna was mounted to the tip of the top cone section...
I used 5 ft of mast to try to get the vertical elements to clear the tower as much as possible "not knowing if if would cause any issue with tuning or radiating pattern." Will it?
This alone in my mind seem like it would be rather straining on the rotor during strong winds.
Id like to mount a rotor inside the cone somehow and run a long mast to mount the YQuad and then the a99 above in on the same mast. Ive found the bushing for the top cap leaving the max OD for a mast of 1.5" This i seems to be the better way to do things especially having a rather heavy combination of antennas on it, yquad at 15lbs and antron guessing at 5-7lbs.
Now to the rea questions, How will i go about mounting the rotor inside the top section of the tower?
Also 1.5 inch mast is alil small i think, but its what ive got to work with to do this. any suggestion on tube to use.
Will the mast being up through the Yquad to the a99 interfere with the function of the beam?
