Stafford PD
DJ88
Brick Twp., New Jersey
#3
I believe 460.275 is used both analog and digital. If you are using the PL, and have a digital scanner, and haven't already done so, try taking the PL off. They may be using it in the digital mode Also, try their other PD frequency, 460.050 DPL 503. At one time, they were using that as their primary dispatch channel. I live in the extreme northern part of Brick and can't pick them up at all, so I can only offer these suggestions.
New Jersey
#6
Perhaps Stafford has moved to Ocean Country TRS
Richard
Action on 460.2750 now 10:30 am friday, talking on portables and said having problems, contact Verizon.
At 1:20 radio repair doing checks on 460.2750 calling it Alpha-2 also talking about staying on bravo channel, talk of phone company also, nothing on 460.0500.
Looks like at 4:10 pm Stafford may be back on A-2 460.2750, lets see how long it lasts. Some transmissions are scratchy here in Toms River, they worked on it all day.
TheManBornWithin
Ocean County, NJ
#7
They have been using Bravo (460.050) for a while now, I'm assuming from problems with Alpha. Reception has been rather terrible in town. Can't wait for them to get whatever the problem is fixed.
EDIT
They are on 460.2750 PL 123.0. Just glanced at the scanner and noticed it changed.
