Stamford CT PD Frequency Help - with a Pro-106
GMAN62465
Fairfield County, CT
Hey there guys,
Back into the scanning scene after a number of years and I know some things have changed since my last foray into this hobby. (Previous radios, Pro-94, Bearcat 200XLT, Regency Tabletop, Bearcat Five-Six)
Just picked up a new Pro-106 and I am having some problems getting it programmed.
I have done lots of reading, searching, and trying multiple attempts at programming it. I have done some programming directly into the radio a couple of different ways but it is not working. I am clearly missing something and could use a hand up.
I feel stupid at this point and would prefer to learn how to program it correctly, instead of buying a scanner preprogrammed. I believe I should be able to monitor Stamford PD but I am just CoRnFuSeD at the moment.
Then I learn nothing new.
Thanks in advance!!
GMAN
APX7500X2
NY/CT
Hi
Welcome back to scanning.
Stamford Police & Fire are 100% Encrypted and you can't get them on any scanner.
The town departments are not and you can listen to them.
Skooter92
Northern Westchester County, NY
SFRD/Volunteer department dispatch.
You can still monitor SFRD/"Big 5" and SEMS dispatch and response on 154.13000mHz with PL 203.5. The "Fire" TG is linked 24/7. You won't be able to listen to any of the various Tac or departmental groups, though. Try listening to CMED MED-5 as well for Stamford area EMS-very informative.
