Stars Programming Tables-Pro-96
JESSERABBIT
Charles Town, Jefferson Co, WV
If this question has been asked and answered previously, I apoligize. I would like to program Fork Mtn on a Pro-96. I understand that I need to set up a table in Win96.
Exactly what do I use as values for everything in in the tables (and I mean everything). I have programmed other tables for other systems, but am not able to make heads or tails of this one. Pardon my ignorance, but any and all help would be apprecieated. Can the table for Fork Mtn be used for any or all of the other sites as well?
fmon
Silent Key Jan. 14, 2012
Eclipse, Virginia
Try either of these. The doc is annotated. The data for tables is retrieved from tower.txt file in the Pro96Com folder after running the program.
For results of some problems with this scanner on STARS, see this thread
Edit: Don't forget to check CC Mult table as in the picture,
JESSERABBIT
Ok, I finally had time to program Fork Mtn. I have run into a problem. I cannot get Win96 tables will not accept a step of 2.5. It defaults to 12.5. It does take the step of 6.25. Is there any way that I can force 2.5? How do I go about it, if it does? I know I must be missing something. I am setting it up as a Mot bank, and using Mo on each freq. Any help would be greatly appreciated. I Am willing to answer any questions about how I am doing this.
