starting to set up up a shack..
JohnnyGalaga
Banned
Nice toys! Once you get the discriminator mod done on that 780 you will be in da house.
brandon
SoCal
YOur off to a great start. 2 of the best scanners and I know you will like the BC780XLT. It's my second favorite scanner follwing the 996!
pinellasfirefighter
Banned
seminole fl
next prodject is a base antenna for 800mhz.. johnny where are you located in pinellas? can you pick up hills , pasco and manatee? i`m having troubles hopefully a good base antenna will do the trick
tonsoffun
Senior Moderator
Moderator
Central Ontario
That is a great start. I remember starting this hobby and had a 10 channel Radioshack!.
Great choice of radios. Shack is starting to look like something now!:lol:
Take care
