static on manual mode
tbharper
Lafayette TN
when im scanning nashville motorola trunk system as long as its in scan mode i can hear them talkin but as soon as i hit manual mode all i hear is static and the talkgroup disappears how can i still listen when i hit manual mode
Bentley
Freehold, NJ (Monmouth County)
Yes, thats normal, its the control channel. If you are trying to monitor one perticular talk group on a trunked system, you must press and hold the trunk button until it beeps while the talk group ID you want to monitor is "talking". This will put you in whats called ID HOLD MODE. You can also lock out all the other talk groups on a trunked system if there is only one TG you want to listen to.
This information is for radio shack scanners only, I do not know how to do it on any other scanner. Although it may be the same.
Sorry for this description, I know its a bit hard to follow. Its late and I'm tired! lol
dangitdoug
tatertot1 is correct. I have a Uniden BXC235XLT. The manual and up/down buttons function the same whether you are scanning conventional or trunking. I al have two RS scanners, Pro92 and Pro95. RS scanners do not have the same ability. What you are speaking of is called Manual Channel Access. RS radios unfortunately do not have this capability
Doug K
