ButlerAlerts
Hello,
As you see I am the owner of the Butler County, PA 911 Feed and we have static. But here is the setup.
Dell PowerEdge R210
Uniden BC355
3.5 MM to RCA then to a Ground Loop Isolator, then to a RCA to 3.5 MM
Then to a USB Sound Card that plugs into the back of the server board.
I am using an external J-Pole Antenna (With crystal-clear audio)
What causes this static? I heard it on alot of other feeds?
Could it be the scanners external speaker jack? or could it be the USB sound card causing this?
Dell PowerEdge R210
Uniden BC355
