Steps for NoIp.com setup
737mech
Clark County, NV.
I have proscan, setup web server, works fine within my network by typing in the url from any pc in the house. How do I get it out so I can log in from outside networks? I set up port forwarding to the pc ip. I setup an account at Noip.com I really need more details how to make this work. I have a netgear nighthawk. I set a static ip for the server pc. I must have missed something?
ProScan
Software Provider
Ontario, Calif.
First check that the Router Port Forwarding is setup correctly. Start the Web Server then use this tool.
ProScan
Software Provider
Ontario, Calif.
I did that and it said my port is closed or server timed out.
Check your Router Port Forwarding again.
You want to use the following:
1. Use TCP (or TCP and UDP).
2. Use the IP address or name of the computer running the server. A common mistake is using the scanner IP address when using an Ethernet capable scanner.
3. Use the same port # as the server.
If canyouseeme still fails then temporarily disable any Internet Security or Antivirus software for a test.
DC31
Massachusetts
Do you perhaps have two routers. Maybe one at the cable modem/router and then the nighthawk downstream of that? If so, then you need to port forward on both routers
737mech
Clark County, NV.
Ok moving forward, cox has a jacked up way to port forward through the modem/router. Thank you DC31! But? It reserved an IP address not on my list. I guess I have to plug the pc directly in to the router, hope it sees it and assigns it? Cox only allowing 1 ip to port forward??
737mech
Clark County, NV.
Got it working thanks guys I knew I would eventually get there. For you guys that know me I'll message the info. I'm not putting this up for public access.
