Still really new to the whole P25 Phase I/II system.
beaker7
Boise, ID
#1
So I'm really new to the P25 system and did read the "So you want to scan a trucked network.." Post pinned to this thread bu tare still confused about it. Is it possible to scan a P25 system using this data (Idaho Cooperative Agencies Wireless Interoperable Network (ICAWIN) Trunking System, Statewide, Idaho - Scanner Frequencies) I would like to scan the local Fire/EMS/Police agencies but they no longer use VHF/UHF. Any help you can provide would be great, Just assume i'm an idiot with the P25 system and 7/800Mhz system when explaining something.
UPMan
Uniden Representative
Arlington, TX
#2
1) You should probably ask that this thread be moved to the General Scanning forum, as it really doesn't belong here.
2) You can scan and monitor any channel on that system that is not marked as encrypted using any modern digital scanner.
beaker7
Boise, ID
#3
I meant to scan this network with a Motorola APX or XTS.
Medford, NJ
#4
Based on your self admitted intelligence level of P25 systems I would suggest buying a scanner. If you really want to use an XTS or APX to monitor a trunked system you need to honker down and start reading all the information out there on how to accomplish this. Its all out there you just need to read up.
IAmSixNine
Dallas, TX
#5
I agree with Skypilot007 please purchase a scanner, take the time to learn how this stuff works, then maybe down the road take the leap into commercial gear.
There are many legalities to know when it comes to using commercial gear to monitor a system, plus you actually can do harm to a system and users with out even knowing it.
beaker7
Boise, ID
#6
Okay will do, do you know any good cheep phase 2 scanner? Also out of curiosity how could someone damage a system? Don't they have ways to stop this?
IAmSixNine
Dallas, TX
#7
one of the issues is when someone doesnt have authority to access a system. Using someone elses radio ID can trigger the system to lock them both out of the system, so if the user cant use his radio that could put that user in danger. Think of a cop whos radio suddenly stopped working or a FF who cant radio in.
I should have used better wording, sorry for that. Damage wasnt the right word, more like cause problems. Its more likely you will get your radio bricked / stunned. This does happen when unauthorized users program radios wrong.
Narrow down if you want a portable or mobile scanner.
From there you have uniden or whistler to choose from.
Ive been happy with my BCD436HP unit.
troymail
Silent Key
#8
"Cheap" is relative but I'd say the answer really is - no. Expect to spend north of $400.... but commercial radio is far more expensive than that.
As far as stopping people from damaging systems - in most cases, it isn't likely that someone having an unauthorized (transmitting) radio can do huge damage to a system (but I am far from an expert on that so others will offer more information there). More likely, from what I've seen - it is possible that if you try to use an unauthorized radio on some systems, your radio will be locked and become worthless (some like the term "bricked"). Again, this is just from what I've read.....
So, I agree -- stick to a (receive only) scanner unless you are an authorized user on a system.
