Stow Police Codes
Nasby
Ohio
If you look in the "database" files under Summit County, Ohio, you will find the codes for Akron P.D. They use the same as Stow, Falls, Tallmadge, etc.
Justin2595
Cuyahoga Falls, Ohio
I know that Tallmadge and Falls have different codes because on scanohio.com they are divided, Akron is the first, then Bath, Copley, and Fairlawn are all the same. And Barberton has different ones, and Tallmadge and Falls have different ones as well. Same with the FD codes. But is Stow the same as Akron?
fpo701
OH DB Admin
Akron, OH
Each does have some differences. Akron has one set. Tallmadge, Mogadore, Cuyahoga Falls, Munroe Falls, and Stow are all very similar to rach other.
One example I can recall that is different is 42. For Akron, it is "half as dire" as 21 (officer needs help). For others, it is something else. I think it is Bank Escort for tallmadge, but it's been a while.
I agree, look at the lists on ScanOhio.com. They should be pretty close.
Justin2595
I also see some differences, In the context that Falls uses signal 75 I know that it is not Use Caution, I think it might be like warrant or something. Thanks for your help.
