Strathroy-Caradoc Police
Forts
Ontario, Canada
#1
Just a note to anyone in the area... if you hadn't noticed, SCPS has been running analog again since about last Friday. I've heard a few grumblings that they aren't too happy with their MotoTRBO setup. I can only assume they will be back to digital before long, after a little tweaking is done.
mikewazowski
Staff member
Central Ontario
#2
I spoke with a tech from a local two way shop that sells a lot of Motorola systems and he was quite surprised that any public safety user would go TRBO at this point in time.
He was concerned that it wasn't a proven technology yet (Motorola just released a major firmware update today) and wasn't intended for public safety.
Hopefully the latest firmware update will help SCPS.
Forts
Ontario, Canada
#5
Technically, yes... provided they aren't using any type of encryption and you were able to get ahold of the proper programming information (not to mention the software, a programming cable etc etc). So it is possible, but it would be a pain. Hopefully they stay analog for a while. Apparently they are having interference issues of some sort while in digital mode.
