Streaming from Proscan to Shoutcast
JeffBH
I'm using the Proscan software to control 3 scanners that I have successful got to stream using the Web Server connection that I can go to and monitor my scanners from anywhere I have internet.
I wanted to try out Shoutcast to see how I'd like it and setup the source client tab to the shoutcast server and seem to have everything correct except I keep getting the error "Stream Name Must Contain A Value"... attached image shows this.
What can I be doing wrong or what do I need to input to make it connect to the shoutcast servers?
JeffBH
Thanks for the reply and email to you was just sent.
JeffBH
Thank you Bob, that fixed it and I can now stream my scanner(s) through shoutcast.
One thing seems to be having a issue is my metadata not found on the shoutcast server but it is on the web server I am streaming.
I'm using the same metadata source.
I have all 3 scanners on my web page ...with the metadata on the BCD536HP and the BCD436HP
Is this seem to be a problem others have had using shoutcast ?
The Proscan web server is doing great...:)
