Streaming PCs?>
BaLa
4GRC+83; Temple, TX 76502
What (kind of comp/scanner) is everybody using for their feeds.
I've thought about getting a cheap PC put together or if I can get my hands on a cheap used PC to dedicate it to streaming and maybe a few other things.
I'm currently using my BCD396t connected to my Compaq laptop.
Specs
Dual Core 2.0 AMD Athlon.
3 gigs RAM
160gig HDD
It's got Vista Home Premium
The Laptop is connected to my WRT54Gv2 Router (running Tomato FW)
:D
So anybody run a dedicated PC for their Feeds?
I'm assuming Scannercast wouldn't require much Proc. Power.
Although I think the earliest version of Windows it would prolly run on is XP SP2.
eaf1956
Evansville, IN
Computer
Specs
3 gigs RAM
160gig HDD
:D
Well, I for one am using an OLD DELL C610 laptop WIN Xp Sp3 I have used a DELL C600 but with the limited memory it runs kinda slow. Doesn't take much to run a feed, I use ProScan for my Evansville, IN feed and right now have a BCD996XT hooked up running Tags and all. I was doing that all WIRELESS but have since ran a 100 Ft Cat 5 cable to the radio area in the back of my house..
Ed
KC9LVX Evansville, IN Feed
bezking
On the Road
A lot of folks use Thin clients (Winterm, etc) as dedicated streaming PCs that run WinXP - they have a soundcard and ethernet port built in and are nice and tiny. They can be had very cheaply on eBay - just make sure you get one with XP!
autovon
Ø
I've been toying with putting a feed up. What model computer should I search for that will do this?
hvscan
Hudson Valley, NY
Wirelessly posted (BlackBerry9530/5.0.0.328 Profile/MIDP-2.1 Configuration/CLDC-1.1 VendorID/105)
I have found some great computers on Craigslist for running my feeds. It doesn't take much of a computer to run a feed. I look for anything cheap that has XP loaded on it.
