iMONITOR
Silent Key
Considering "Stridsberg's" products only, (not interested in Mini-Circuits ETC)
I've owned a Stridsberg MCA204M 4-Port multicoupler with preamp built in in the past. I used it on a DPD Production's MilTenna Omni UHF/VHF Base Antenna to feed two scanners for VHF/UHF aircraft and it worked great! Low noise and substantially increased signal without causing overload.
Now I'm considering a similar amplified multicoupler for Michigan's MPSCS simulcast system. I was going to buy another MCA204M (25 MHz to 1 GHz), but then I noticed they also have a MCA804/B model that might be better suited. However it is only rated for 830-910MHz, where MPSCS falls approximately into the 760-860MHz. So it appears the MCA804/B goes does not go down into the mid 700MHz spectrum where the MCA204M does. What would be the pros & cons of both?
