Struggling to program P25T TGID
yiddishmeatball
Greetings! I have been trying to program my G5 for a while now and I am struggling to get P25T TGID to show up in the settings. I have added the protocol as shown below:
But it refuses to show up when in Group Parameters:
When I add conventional and DMR to the Protocol Parameter Settings, they show up properly in the Group Parameters:
I attempted searching and found this post Unication PPS 4.0 Can’t See Talk Group IDs. I added the site to the P25 Trunking System Manager and it didn't seem to make any changes.
Anyone able to assist me with what I may be doing wrong? Thanks :)
What FW and PPS are you using? The versions of the PPS are different and we need to know to give you the proper advice. Based on the screenshots, it appears you are using an older version of the PPS.
yiddishmeatball
Apologies! I am currently using:
Version V0.4.0.41
Firmware Version: V2.02
DB Version DBV2.04
So you are trying to create a new profile? Why not start by reading your pager instead?
Go to tab E and select READ DEVICE, so it gives you all the correct pager information.
Are you trying to add a system and talkgroup or a talkgroup to an existing system?
yiddishmeatball
I added the P25 Trunking System and I was trying to program the individual talkgroups that I would like to hear (instead of the whole monitor). Just to be safe, I factory reset my device and had it read the device to start the new profile. It still appears to have the same issue where its not showing the P25T protocol information in the E6 tab, even though its been enabled in the E4 tab...
