I’m guessing from the meter, it looks to be about 60 or so when I’m talking on it. I don’t know a lot about cbs but yet I’ve been running them for over 20 yrs for work. I appreciate any suggestions or help. Thank you.
Without being there, this is a guess:
I think the high RF levels are getting into the light bar wiring and messing with the controller.
Probably two possibilities:
1. Poor shielding on the light bar and/or light bar wiring.
2. Too much power out of the CB getting into the light bar and wiring.
A couple of things you can try:
1. Lower the power level on the CB. If you are doing pilot car stuff, you don't need 60 watts to talk to another vehicle in the escort. Try that and see if the issue resolves.
2. Move the CB antenna away from the light bar. Putting more space in between them will lower the amount of RF that's getting into the light bar.
Or, try both if neither works on its own.
The light bars used on public safety vehicles are designed to be run in this sort of environment. I have antennas running 100 watts VHF as well as 800MHz close to the light bars, and we don't have this issue.
Other possibility is that if it's a magnetic mount, like slowmover was saying, those can put a lot of stray RF on the coaxial shield, and that can find its way back down into the vehicle to the light bar controller.
It may be more complex than that, but those are the easy things to try. You may need to move the CB antenna, and lower the power to resolve it. If none of that works, you may need to consider a higher quality light bar with better shielding/design to prevent this.
I think the easy solution is to turn down the power on the CB, there are times when more power isn't better.
