Stun\Kill???
bezking
On the Road
What's the difference??
How does it happen??
If a radio is stunned, is it dead forever? Killed?
Thanks guys.
WayneH
Forums Veteran
Super Moderator
Your master site
The only system I know of that supports stun and kill is PassPort trunking. Basically, one is temporary and the other requires a trip to the manufacturer to reset (ala Motorola).
For Motorola there is only selective inhibit, which turns your radio in to a brick and requires it to be sent to Motorola. That's true if it was programmed with CPS; if it was done with RSS you can read and reprogram it.
EDACS is similar to Motorola. I'm not sure how permanent the feature is.
bezking
On the Road
Can the selective inhibit be done from a manager's radio, or does it need to be done at the dispatch console? How is the radio to be inhibited identified? Sorry for my being so naive.
WayneH
Forums Veteran
Super Moderator
Your master site
A console or a systems terminal. It can't be performed directly from a subscriber radio.
There are a variety of ways a radio can be identified. Everything goes to a log. It's all about how you parse it and what you're looking for.
grem467
Houston, TX
keep in mind wayne, that certain new icom radios can reportedly send the MDC1200 inhibit command directly from the radio...
WayneH
Forums Veteran
Super Moderator
Your master site
True, but we're in the Trunking forum. ;)
MDC is definitely underated anymore. It's a pretty decent protocol for more than just PTT-ID.
bezking
On the Road
Ohhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhh - thanks Wayne:D
motomeso
Ontario
The Passport Stun and Kill commands can only be sent from the NTS commander software while logged into the site remotely or directly.
The stun command just disables the radio on that system, when it tries to register it shows disabled and honks at you (Waris series radios) but will still operate on other channels. This is usually done for seasonal customers or customers who own their radio but choose to discontinue their service.
The kill command turns the radio into a nice door stop and is usually reserved for stolen radios. It could also be used for rogue users but with Passport needing a MIN number (Mobile Identification Number) along with ESN validation the chances are pretty slim.
WayneH
Forums Veteran
Super Moderator
Your master site
Isn't there an option that by default any radio not in the database registering with the system is automatically stunned?
XTS3000
The Jaguar700 can have a suicide command sent to it - even the manufacture can not revive the radio EVER.
Stunn & inhibit are basically the same thing - recoverable. Suicide is just that, the radio commits hari cari.
bezking
On the Road
I believe so.
That makes sense ONLY if it is stolen - from what I hear on RR Jaguars are NOT cheap.
EDACS appears to support two levels ... inhibit and kill. There's an un-inhibit command but no un-kill command. I thought the "kill" command nuked the radio's profile but didn't physically damage the radio (but, hey, I've been wrong before).
rescuecomm
Travelers Rest, SC
The Icoms that have over the air stun/kill are using the Transcrypt module to do this. The radio itself will probably still work with a analog program.
Thayne
My Jaguar might have 9 lives, it has been resurrected twice so far (With a little divine help)
morganAL
Somerville, AL
In EDACS, in the CSD (Communications System Director), you can specify a radio to not be valid on a system which means the radio can still rx fine but when it tries to transmit, it gets denied and no working channel is assigned. You can also send a unit disable command from the CSD. This essentially turns the radio into a brick. You can turn the radio off and on and that is all it will do. If the situation warrants, you can also re-enable the radio from the CSD. The only other option is to have the radio reprogrammed. Neither affects the radio's personality data. If the radio is feature-encrypted for it, the CSD can send the radio a temporary list of up to 8 TG's. This is called Dynamic Regroup Once again, the original programming is left intact. This is useful for situations where a group of radios needs to have a TG or several TGs that they don't normally have. When they are finished, the radios are then "ungrouped" from the CSD.
