Substitute Replacement for Midland MA100/MA105 Microphone?
KK6HRW
The original microphone (MA100) on my Midland MXT MicroMobile GMRS Radio has failed and it (and also compatible MA105) are out of stock. Does anyone know of a alternative replacement?
Hans13
The 40 watt Midland was a rebadge CCR with a locked down firmware. I posted the model name and number on MyGMRS sometime ago. That could be a source of the microphone. I will take some time and research it when I get a moment if nobody else comes back with an answer.
KK6HRW
Unfortunately, I hadn't researched any more since the earliest Midland Micro Mobiles. Any of my information wouldn't be relevant to the MXT line.
Is this one on Amazon close? https://www.amazon.com/Midland-Replacement-Microphone-Off-Roading-Overlanding/dp/B0BQLYNZ74/
It turns out that microphone in the Amazon link is the same as the one I already have in a different vehicle. I then compared connectors and, because the newer microphone controls many more functions, it’s connector is much wider than the one on my older failed mic. Thanks very much for all of your research on my behalf! Bill
Hans13
Sorry I couldn't help you solve it. Hopefully someone will come along with a suggestion for an alternate source.
KF0NYL
That info might help us narrow down the search. You are looking for a Midland hand mic with a RJ12 connecter.
KF0NYL
I should have added that the Midland hand mics with a RJ12 connecter will only have 6 wires while the newer mics with the wider RJ45 connector will have 8 wires.
