Super Bowl 56 online feed
Lllsssrrr000
Anyone know of an online feed for Super Bowl 56
Maybe LAPD or any other agencies that will be working the event
Eng74
Kern County, CA
I would not be surprised if LA-RICS is not used. It is Inglewood so they will be the lead PD but LACoFD is their fire/EMS.
LAflyer
Global DB Admin
Moderator
SoCal
95% of the activity will be on LA-RICS (and encrypted) since the primary SoFi stadium agencies are Inglewood PD, LASD and LACoFD.
Other than that I have noted LAPD has been on OCB Tac-1 and CW Tac-2 for the Super Bowl experience at LA Live/Convention center this week.
Also, CHP guardian units running various team and event escorts on Blue while some other stadium-related stuff on Tac-6.
Inglewood PD looks to have Ch4 with some random chit-chat outside of LARICS use.
Also heard CALTRANS on their 800Mhz working in the area for last couple weeks with various sweeper trains and clean-up crews.
pewpew45
I've heard all law enforcement including feds will be using larics and encrypted with the exception of mutual aid 2 conventional which is interop. Also chp on some of their channels.
Fire will be on the event larics talkgroups though in the clear. Would be great if someone streams the clear talkgroups
f40ph
Largest County, CA
Be sure to listen to any interop repeaters. UTACs, VTACs, 7TACs, and 8TACs. When they pre-plan these events, they sometimes grab these especially if they're already part of the local infrastructure.
ChrisP
Portland, OR
I am curious why they did not set up one of the Site On Wheels (SOW) for LA RICS here at SoFi? I don't see any of the SOWs showing on line now.
- Chris
Lllsssrrr000
yes
would be good if someone could stream any of this
thanks everyone for your info
ChrisP
Portland, OR
Most of the Stadium talk groups on LA_RICS are encrypted. EVENT 1 appears to be clear.
While the federal agencies have access to LA-RICS, there are quite a few federal VHF & UHF frequencies here at SoFi in use as well.
- Chris
LAflyer
Global DB Admin
Moderator
SoCal
For CHP, besides the Blue, they have activity on Tac-6(45.06) and Tac-8(39.14) plus sound like moble command post has a 700Mhz base repeater going on 774.80625 NAC 7E0
LAFD providing some support seems to be using STRS TG 151, 153, and 163.
Also 8TAC92 852.0125 has air/ground comms - seem to be Federal aircraft
tsalmrsystemtech
After the Super Bowl there is a lot of Traffic on the LAPD Tacticals like Central Bureau Tac 1
