Super Track?
Oldglide
Metro Chicago
When using the object editor in PSREdit 500 there is a box labeled "Super Track" which is always checked. I cant find any reference as to what this is or what it does.
W6KRU
Vista, CA
In the Expert Menu are a couple unusual items. The first is called “SuperTrack”. This is a method of changing the way the radio processes digital signals. Since each digital system has slightly different parameters, this adjustment can help make decoding a bit more reliable. If you are having difficulties with a channel or system’s digital decoding toggle the SuperTrack setting on or off to see if it helps.
