Surveying radio reception before installing antenna
jdm1
New York, NY
I'm considering a few different sites for a new antenna installation. I'll be monitoring a number of frequencies and then streaming them to myself over the internet, so I have some flexibility on where to install.
I'm looking for recommendations on how to do a survey of radio reception across these sites before deciding where to locate my antenna. What types of devices could I be looking at and how could I automate this process? I'll be monitoring primarily UHF/VHF public safety channels.
Thanks in advance for your thoughts.
popnokick
Northeast PA
You are climbing each tower with a portable receiver and / or a spectrum analyzer, correct?
jdm1
New York, NY
Yes, they will be mounted on a rooftop and I will have access to each site. I have set up a dipole antenna on a rooftop before and used police scanners, but have never used a spectrum analyzer before. My main question is what equipment I should use and if there are best practices for doing these types of surveys efficiently.
prcguy
You need a spectrum analyzer and preferably with a peak hold feature. This way you can let it sweep a range of frequencies and it will display a trace with the maximum levels recorded for the duration of the test. Then do it again at other locations and compare the levels.
prcguy
jdm1
New York, NY
Thanks for the thoughts. I ended up connecting a scanner to a laptop with Arc XT Pro to do some preliminary signal strength measurements
