- Joined
- Jan 2, 2018
- Messages
- 169
i live in Fremont i can hear anything i live right across from Santa Clara
This thread is intended for questions regarding SVRCS. For example;
how to program
reception issues
etc
The other thread is intended for SVRCS updates.
For example;
Discussing users on the system
New talkgroups
Having seperate threads regarding SVRCS will help out some of the clutter in each, which is similar to what we did with the EBRCS thread.
Thanks for everyone who has contributed to this thread and database entry. Since so many folks are interested in PS over IG, I don't typically contribute to PS systems. As I saw some more TGIDs trickle in, I became more interested in this system. I live in Mountain View, and can copy the West Cell very well.
I see that there are TGIDs assigned to MV. Does anyone know when they will actively start using the system?
I decided to setup my SDS100 in Trunking Discovery mode to see what else I may be able to contribute. After a couple of days, here is what I found:
1151 - Confirm that it is Los Altos PD. I just missed the DB update for this TGID, and it showed up as "new" on my radio.
1509 - Not present in RR DB. It sounds like Animal Control for Palo Alto, Mountain View and Los Altos. It falls near 1501 and 1502, which are TGIDs that are assigned to PAPD.
4790 - Not present in RR DB. It falls within the VTA talkgroup range, between 4781 and 4797. Don't know VTA traffic well enough to know if this is assigned to bus or rail operations.
4794 - Not present in RR DB. Sounds VTA related.
4796 - Not present in RR DB. Sounds VTA related.
Will need to setup another radio to scan VTA frequencies to see what may match up.
The mode column provides us with 2 separate pieces of information (in this case). First, D, means Phase I digital; where a T would mean Phase II digital (for example). The added E (or e for part-time encryption) indicates the channel is encrypted.My question (and maybe this should be asked in the DB forum)… How long is a reasonable amount of time to monitor a TGID before it should be marked as "E", instead of "DE"?
