Swissphone pager programming
lrcrabtree
Mi Wuk Village, CA, USA
I have searched far and wide for the PC programming software for the Swissphone pager RE729 with no luck. I think the software is called "PSW 729" or "PSW X29" and is model specific. We have the cradle and cables, just no software. I am looking to acquire a legitimate copy, not a pirated copy, but even on Swissphone's website I can't find anything. Does anyone know where else I might look?
Larry
KevinC
Moderator
Super Moderator
Somewhere other than home :(
Larry
Have you tried contacting them? It may not be listed on the website, but still be available.
These people sell the cradle and software, maybe try contacting them...
https://www.pwservice.us/CP/Scripts/prodView.asp?idproduct=649
lrcrabtree
@KevinC, thanks. I did that from the Contacts page on the website, and within 48 hours I received a response with a hyperlink to the latest software. Good response.
@Res21cue: I'm curious why you say this is the worst pager ever?
Larry
krokus
Southeastern Michigan
Worst...pager...ever
Very subjective. My current department tried a couple of them, but some people did not like having to learn different controls.
Some departments in my area use them, and they work well.
The volunteer fire brigade I was a part of, overseas, used Swissphone pagers, and they worked fine.
Sent from Tapatalk
com501
FDs still like Minitor Vs until they will be EOL'd soon, and then who knows whats going to be available. A lot of our commercial customers have been deep sixing their PR3000s finally and getting Swissphone. They take some getting used to, but you can at least service them.
jeatock
090-45-50 W, 39-43-22 N
Software
Jake at Swissphone can help you out. The software is license key activated. Call (800) 596-1914.
RE429's are bulletproof, 529's are OK until they get dropped hard a couple of times and dislodge a filter, 629's are OK, but the 729's with the VOX software rock. I carry a RE729VOX in open scan mode every day, and the reception on 4 channels is pretty close to a regular portable. Alerting is head and shoulders above the M-V.
The biggest complaint I hear from Firefighters is that it is different. No knobs to bump or fall off. And we all know Firefighters lead the charge to every available change (NOT!).
TampaTyron
Tampa, FL
I can also confirm that Jake will get you straightened out. He got me up to speed back in the day when Swissphone first arrived here in the US. The learning curve was steep due to having to hand tune each pager before it shipped out...... I hope they have improved that process in the last 5-6 years. However, once they were tuned, they could hear signals that a Min V never knew was there......... TT
ocguard
PA/MD
I've been using my 729 for a few weeks. Because of how many profiles for different units I work at, I didn't have enough profiles left for a monitor function. Other than that, I LOVE the pager. It's flexible and powerful. The setting change method takes getting used to. But I wouldn't go back to carrying a bulky MotoMini5.
lrcrabtree
Thanks for all the responses. Swissphone representatives emailed me a link to the programming software and all is well. I reprogrammed the first one and test drove it. Tweeked it a little and test drove it again. Working great, so last night I reprogrammed the other two that we have. Now I'm looking for a few more.
One question: How do I tell if ours are the RE729 (Classic) or RE729VoX?
Larry
kingofengland
Bryant, Arkansas
Programming
Larry
Can you email the link to the software? I just joined a small volunteer FD here and they gave me a pager that is unprogrammed. They also handed me a couple of others that need need programming. It is going to be a week or so before I an get to our radio sales business and I would like to be able to program them myself. I already program some other radios, etc. I filled out the web form for the Swissphone people to contact me yesterday.
Thanks,
Scott
Since it appears that the software is free to use I don't think this breaks any rules. If it does please notify me and i will remove the post.
lrcrabtree
Software
When I asked for the software the Swissphone representative emailed me a link to download the software and didn't mention anything about paying or purchasing. I assume therefore that they distribute the software freely to swissphone pager and programming cradle owners. Based on that I am going to post the download link to the swissphone site here. If anyone knows otherwise (i.e. swissphone sells this software independently), please let me know and I'll take the link down.
https://dl.dropboxusercontent.com/u/14873955/11 Pager Software/RE729/PSWx29_Standard_4_52.zip
Larry
kingofengland
Bryant, Arkansas
Swissphone pager driver?
I installed the software and I don't have a serial port or a serial cord. I tried to use the supplied USB and it will charge the pager but when I start the software it says that comport 1 is not available. Is there a driver I am missing? I tried turning the pager off and turning it back on in case there was a driver that needed to automatically load, no luck
Thanks,
Scott
kingofengland
Bryant, Arkansas
I figured out the problem, you have to have their programming cradle. Oh well, it was worth a try. Thanks for the help. By the way the software is free.
