SWR Question
JohnnyFingers
Vancouver, B.C.
I have a Uniden Bearcat 980 SSB CB Radio. It has an onboard SWR meter. In addition I have an Astatic PDC1 external SWR Meter. I have matched the readings between the 2 and they are pretty much on par. below are the readings with both.
With the Astatic PDC1 meter attached to the radio:
The Astatic meter reads an SWR of:
Channel 1 - 1.49
Channel 40 - 2.51
With the Astatic PDC1 meter attached:
The radios SWR meter reads:
Channel 1 - 1.45
Channel 40 - 1.82
Without the Astatic PDC1 meter attached:
On the onboard SWR meter reads:
Channel 1 - 1.43
Channel 40 - 1.10
The 2.51 reading with the meter attached is what concerns me. No matter how much adjusting I do to the antenna that number remains high
So which meter reading do you guys suggest I go with?
By the way the radio is installed in my car.
slowmover
Fort Worth
When in doubt (your dilemma) tune to the channel you use until you have changed locations. If that channel is AM-19 you know you are GTG at present.
My U-980 tends to be optimistic versus the A-meter. Could be bad jumper, faulty meter, etc.
Once you are in a wide open field far from any trees or structure as best you can arrange (with doors shut and a new jumper), let ‘er rip.
I
slowmover
Fort Worth
I used to set my Chrysler at the house. Then I’d run a good forty miles or more — not a pain, a pleasant drive, I rebuilt that car for it — and unfold that 9’ whip at a VERY wide shoulder on an overlook free of obstructions.’
I’d take my time and make notes: under best conditions, readings were . . .
JohnnyFingers
Vancouver, B.C.
I have mine installed in a 1969 Chevelle SS. Im also looking into getting a CB radio from that period. A modern radio doesn't look so good in that car.
