Syntor x9000 programming issue
#1
I have a Syntor x9000 that i am trying to program. I made a programming cable out of one ot the T cables used to connect a rear control head that is connected to my RIB. When trying to read the radio or head I get an error message that says there is a power fault. The radio powers fine without error codes, and I have a fresh battery on the RIB. Any Ideas?
K
kb0nly
Guest
#2
Got an OLD computer?? Your gonna need an ANCIENT laptop or desktop. I found anything over 50Mhz won't reliably program X9000's. If you can find a 486 of the 25/33Mhz vintage that works great for me.
I know it would spit random bus and power errors when i tried anything faster.
wcu02mpa
Asheville,NC
#3
Computer will fix that
Assuming your cable is correct and RIB is correct, KB0NLY is correct. I am able to use an aftermarket RIB, but when I tried a pentium-1 computer I got the power fault message. I use a Toshiba T5200 laptap and it works great. I have programmed many of those X9000's and have had no other programming issue. What band are you trying to program? Low, VHF or UHF? I keep a lowband in my vehicle and it works both 6 and 10 meters great.
#4
I am trying to program a T74 (100 watt UHF). I aquired an old i486sx 25Mhz, and have tried that. I am no longer getting the power fault message, but when I start to read the radio or head eeprom it displays "Reading Radio EEProm" and hangs. I thought these old dinos might be a little slow on the data x-fer, so I left it there for a while, which turned into a couple of hours. I thought it was the computer that froze, but when I turned the radio off, the RSS returned to the menu screen.
Tulsa
#5
K
kb0nly
Guest
#6
I second that, build new codeplug from scratch and dump into radio. I hardly if ever read an X9000 unless i don't have a backup saved for that radio and the owner just needs a few things changed on the existing programming.
#7
Partial success
OK, I have been able to program one successfully! However, I have another identical unit that I tried following the same procedure with. It starts to program, then throws a protocol error after block 1. I even built a new personality for the head and radio instead of using the saved ones from the other radio. Ideas?
Thanks for everyones help btw.
Tulsa
#8
Check the ROM size, if I remember correctly a X9000 could have 2K or an 8K, there is a pin chumper that you move from one position to the other depending on the ROM size. Could be you have a 8K and a 2K radio. You need to read up at Mike's website.
Back several years ago I had a pair VHF and UHF with the dual radio cable and the SP dual radio head installed, but pulled them when I sold the vehicle.
K
kb0nly
Guest
#9
Yep, both and 8k and 2k radio. So if you tried programming an 8k codeplug into a 2k radio you would get that error.
If you have a 2k radio you can update to an 8k radio by tossing in a larger EEprom, did that a lot on these.
#10
Ok, tried the 2k and 8k codeplug, both give me a protocol error. this is the only radio that has given me this error. I have done 3 other x9000s with no issue, Think the prom is fried?
Tulsa
#11
Your X9000 may have the firware for a dual-radio setup the chip should have a paper label with the Motorola pn on it, compare that pn with what you have on a known good radio. I don't remember the industry number but you can find them and take a known good one read it with your PROM programmer and save it as a .bin file then put a new chip in and write the bin file to it and have a duplicate chip. If you can find a used chip you can peel the label off and put it in your UV eraser and then reprogram it.
