I have System Scan (SYS SC) mapped to a side button on the 700Pi KRD and the radio goes through the motions... emits the button press beep and indicates on the display SYS SC OFF/ON however, the radio will still roam whether it's toggled on or off.
With the P7100/5100, P7200, and 700P/Pi RU toggling System Scan OFF locks the radio to the current site and prevents the radio from roaming when using Proscan on EDACS.
With the 700Pi KRD it doesn't seem to matter whether SYS SC is off or on,it will still roam regardless.
Is the EDACS/P25 Priority System Scan feature the Priority System function of ProScan?
I ask because EDACS/P25 Priority System Scan (05) isn't enabled in this radio,but it does have EDACS/P25 ProScan (ProSound / Wide Area Scan) (06) enabled and the radio will correctly lock onto the system set as the System Scan Priority System under the System Set-up tab.
