System Wide Reports - TETRA
W1RHW
MoCo, MD
#1
Is there any reason why "TETRA" is not an option for the nationwide trunked system reports? I could be doing something wrong, but I curious to see all the TETRA systems in use in the United States and there was no easy way to do it.
Thanks in advance!
W1RHW
MoCo, MD
#3
Thanks Lindsay!
Although monitoring TETRA is currently relegated to software-based monitoring and mostly utility companies only, I will find this helpful for some experimentation.
