Saudi Arabia.
Hello.
The highway patrol are on low band, 70 to 74 MHz, FM, no encryption.
The UHF system you hear is the phase III network.
Phase I is all analog, UHF, DTMF signalling.
Phase II is Motorola trunking.
Phase III is to be a mix of TETRA and P-25, an experiment if you will, encryption is not normally on, perhaps this has changed?
In the 153 to 165 MHz range is all manner of communications, a lot of telephone and the like, marine, everything.
And, yes, voice inversion, DTMF signalling, the whole bit, and way overloaded in the city.
GSM at 900 and 1800 is the norm for cellular.
On 146 to 153 MHz are the security forces and border guards, not to listen! as well as the A side.
Channel numbers for VHF are, 0=156.0, 6=156.3, 16=156.8, to 59=156.95, channel 60 jumps to 156.025, 66=156.325, 241=162.025, jump to 242=155.975, 281=155.0,.
Past 281 it is letter codes, this board will not allow the Arabic figures.
The radio will do trunking in a format called IMTS, except for the marine channels.
The A system is on 148 to 153 and the B system is the other half, 163 to 168 MHz.
I can not explain it in simple terms, it is a duplex system sometimes, and at other times not.
The split for the letter code system is always 15 MHz.
For the number code it is always 4.3 MHz.
Now, here is where it gets complicated.
If a public station is involved it will always transmit on the high side, so channel 241 you would listen for 166.325, except that is not the case, that frequency is for the letter code side, so you have to switch to the letter code system.
Radios are programmed for this.
And, to further confuse, some channels are marine only, others government only.
But, the way it is configured, an analog radio will always work.
Find an idle duplex channel, this will have a high pitch tone, transmit and say something, and wait for the operator.
Progarmming a scanner? I would not know where to begin.
Remember, there is this "idle tone" to deal with, a squeal.
And, although it may be legal to listen to police, royal guards are never happy about radios.
