Systems Saber programming question
scansomd
Southern Maryland
I am using RSS R04.00.00 to program my recently acquired Systems Saber III.
Before I ever programmed this radio, I assumed zone one would be channel 1-16, zone two would repeat its own channel 1-16, etc. From what I can tell thus far, the channelization is 1-255, then you somehow point individual channels to the zone you want it to be in. Am I correct?
Also, what is the best way to obtain a copy of the RSS Users manual?
FFPM571
Nashvillle
You are correct. Assign a personality( channel) to a zone.
RSS manuals are hard to find. Its not even avalible on the Motorola Online Website. Standard Saber RSS manuals are.
wdatkinson
Noblesville, IN
One other thing that aggravates me a bit....
When you're planning out your channels, there is no way to keep modes 1-16 in zone 1 and 17-32 in zone 2, assuming less that 16 channels per zone. As you add/delete modes things can get quite messy.
The Saber II is a little better at this, but the Systems Saber III and the Astro Saber are not.
scansomd
Southern Maryland
I am tracking the way I want the radio programmed on an excel spreadsheet.
So,,,,,, I could program all 255 channels in, without regard to which zone they will be in, then just go back and assign the channels to zones? i.e., channels 1, 57, and 89 can all be in zone one.... Do I have it right?
wdatkinson
Noblesville, IN
Yes, you have that right. I also use a spreadsheet to track my radio config. If you'd like, I'm happy to email you a copy of the spreadsheet I use, if you'd like to see it. Just PM me with your email address.
As an example, When I initially started programming my radio, I had modes 1-11 assigned to Zone 1. I then went on in my config and setup Zone 2, 3, etc. Later I came back and wanted to add a couple of channels to Zone 1. So I added those modes at the end of my list for the entire radio, modes 50 & 51 for example. Then I went back to Zone 1 and added those modes to it. So if you look at zone 1 in RSS, you'll see modes 1-11 and 50 and 51.
Make sense?
scansomd
Southern Maryland
PM Sent.
I am starting to make sense of it.... I am going to spend some time this afternoon on my DOS Machine working on it.
Make sense?
smokeybehr
CenCal
So,,,,,, I could program all 255 personalities in, without regard to which zone they will be in, then just go back and assign the personalities to zones? i.e., personalities 1, 57, and 89 can all be in zone one.... Do I have it right?
(terminology corrected for clarity)
That's exactly it.
I built a special load for the AS by entering all of the frequencies with the PLs in order, then just picked the personality and put it into the correct zone/channel with the appropriate alpha tag.
radiolan
SE PA
in similar situation
I have read through this post and it has been quite helpful.
My problem is that it appears that I have only 8 of the sixteen channels available in RSS with my SSIII.
I simply cannot determine how to assign one of the personalities/modes beyond ch.8.
T1 through T8 are all that appear, nothing beyond.
Any help would be greatly appreciated.
I'm using R04.00.00
thanks
jack
**************** CANCEL ABOVE **************** I used the F1 key !!!!!!
brian0007
new york long island
hey guys . i know this is an old post . i just got my hands on a systems saber , saber and a m120 base/mobile radio all vhf . i know i need different rss for each . i was able to get into the m120 on my vista computer . is that going to be completely impossible with the saber radios ? is it straight dos or will an older system with 95 or 98 work with it ?
thanks in advance .
RKG
Boston, MA
thanks in advance .
Native DOS only for both the Saber and systems Saber.
