systems used in area? scrambled?
doc7411
These are the systems used in my county will I be able to get statewide law enforcement on a digital scanner and how do I know if the single is scrambled or not ? Thanks Brian
Type City
COM-SAV LTR Standard New Port Richey
Pasco County EDACS Standard Pasco County
Progress Energy (Florida Power) Motorola Type II SmartZone Various
Southern Company LINC 800 MHz (Florida) iDEN Standard Various
Sprint Florida Motorola Type II SmartZone Various
Statewide Law Enforcement Radio System EDACS Networked Standard w/ESK Statewide
what do you mean by scrambled?. you will be able to pick up all except Southern linc & perhaps the 2 EDACS systems if they are Pro voice digital, ESK EDACS I am not sure about
jb872033
Cromwell CT
simple...program and listen...if you can hear all the traffic and your scanner can trunk track them they arent scrambled (encrypted)...listen for a while though...scrambling is not to be confused with data burst that you will reguarly hear on some types of trunked systems...
JB
Taloniilm
NE Texas
All Florida state agencies are encripted, you can't monitor them. There is a good "sticky" in the Florida forum that specifically addresses SLERS,(State Law Enforcement Radio system), FL statutes regarding scanner use in motor vehicles and much more ... take a look.
n2mdk
Ames, IA
Forget about the iDEN system. All the other systems can be listened to will less expensive trunking scanners. the Statewide system since it's EDACS ESK can only be monitored with the new GRE digital radios the PSR-500/600. It does use ProvVoice so if any TGIDs using it can't be monitored. Nothing there shows as encrypted.
n2mdk
Ames, IA
Are they encrypted or was it a case of no scanner being able to receive the ESK. Since the new GRE's can does that sticky still stand. If they all use ProVoice then it still remains unscannable.
W4KRR
Coconut Creek, FL
State of Fla system is completely unscannable due to encryption on all talkgroups.
N8IAA
Fortunately, GA
Type City
Yes
Yes
Yes
No
No
No
There are conventional frequencies that you can monitor also.
Larry
