T-hunting or Fox hunting questions !! help me
SoCalRepoDude
SFV area
well here is my issue i know a lot of people know this as fox hunting well we call it T-hunting... Anyways my set up is a 4' firestix with dead whips for a wall im running a cobra 29 nightwatch ltd sometimes i get a good direction and read and tag all night then another night it seems like someone cut my coax or mess with my ground and i cant figure out what and how to fix it try to run just a 102" stainless whip on the rear driver side of my pick up but that wasnt that good either i ran ground wires from the engine block to the pick up bed helped a little but not enough! so im seeking some help im sure there is more of you that knows more then i do!!! please help
kd7gxu
Archer, WY
questions
How are you getting direction finding with one vertical antenna? Your best bet on 27 MHZ is probably a loop antenna and a step attenuator. The loop will give you a null in one direction and as you get closer you can use the attenuator to reduce the incoming signal so that a direction can be read. I suppose you could use a rotatable dipole or yagi on top of a vehicle but it would be kind of large on 27 MHZ.
efry849
Pembine WI
T-huntingor Fox hunting
Ham radio is a popular venue for fox hunting. I dabbled in it years ago with 2 meter vhf. We always used directional antennas to determine direction of the signal source, then step-attenuators to close in on the fox. Check out arrl.com (American Radio Relay League, the voice of ham radio) for links & info on fox hunting. The concepts are the same, only the frequencies differ. Good luck & have fun.
Ed, N9MBG efry849@plbb.us
kb2vxa
Banned
Point Pleasant Beach, N.J.
Considering this is a CB topic I have doubts if any of the antennas or techniques used on 2M (the most popular fox hunting band) would be of any help. I don't think there are any loop antennas sold anymore or plans on how to make them like there used to be before the madness set in but if you can find any publications from the early 70s you just might dig up some useful information.
Fox hunting is very popular in Europe and those hams make life miserable by putting transmitters on bands where they're extremely difficult to track but they love it. That may give you some idea where to look on the web, there are clubs and they have web sites loaded with information. Being 11M is HF some of their antenna designs may give you some neat ideas.
Hmmm, practice makes perfect and perfection makes a midnight antenna party when you find that carrier chucker. Just be sure you're perfect and not like Fudd the hunter who didn't realize who he was mouthing off to until I rearranged his face for him. (;->)
DX949
Banned
You rearranged his face for him ? Did you hit him with your mic or your golden screwdriver ?
Let me quess..........your going to show me a picture of your Browning and a set of brass knuckle...........lol..............let us not forget Robby the Robot..................lol.......just kidding...............I'm imature what can i say :0)
mitaux8030
Home
Its not hard to fox hunt on 27 MHz if you want to.
A local group of radio enthusiasts run two versions of fox-hunts on CB: the first has the fox giving out clues every 5 or 10 minutes as to his location, and so combines technical skills with trivia like knowledge. This is great for those participants that don't have or like to use technical means to find the fox.
The second fox hunt run we do is a pure fox hunt where someone takes a handheld CB and hides somewhere, no clues given, and its up to the hunters radio finding skills alone to catch the fox. We frequently find participants with no directional finding equipment at all manage to find the fox first... I guess they're going purely on signal strength alone, and then when in the general vicinity they'll visially search out the fox. So hunting a radio-fox with verticals alone can and does work!
We've had foxes hide inside a local McDonalds or grocery store, inside a rubbish bin, next to a sewerage plant (peeeuw!) and all sorts of inventive places. Techniques used by hunters are just as inventive: using hills, road cuttings, buildings etc as an indication of signal direction (ie if you're in front of the hill / building the signal doesn't drop, but behind it does etc), when getting stronger signals swapping to progressively smaller antennae, and finally using no antenna at all to really zero in on the source.
Quite small (about a foot across) loop designs exist for 10/11 metres that are quite directional. They shouldn't be hard to find. If you find one for 10 metres ham band, it'd be quite easy to adapt for 27 MHz - in fact the one and same loop would probably do it just fine.
