T3011DX DES-XL KVL Questions
RFI-EMI-GUY
Can anyone tell me if there is a way to tell if a particular T3011 series KVL has the DX firmware installed? I have a DX model on the way and don't want to take it apart to have to check if the correct firmware is installed. Also I already have a CX model and suspect it may actually be a DX upgrade.
Does the top level menu provide any clues> Is there a test function to reveal firmware version?
bk117
Philadelphia
Easy - While depressing 0 and 3, press PTT. The display will read busy followed by the model# and release version. After that a keypad test will begin and you can press the keys in the order displayed. To exit without the keypad test you will have to remove the battery. The information flys by so fast you may have to repeat it a few times.
Brad
RFI-EMI-GUY
Brad
Thanks. That was very helpful and good to know my keypad works as well. It indeed took several tries with two KVL's I have on hand to capture the digits.
The first is a T3011CX and it displays 3.3 155.A, the second is a T3011AX and it displays 1.0 155.A.
I have two binary files found on the interwebs: One is named TVN6087B T3011CX.BIN. When viewing with Hex Edit it shows a 1990 date and version 3.3 in the text field. So I assume my CX is indeed a CX.
I have a second binary file labeled TVN6140.BIN, which was supposed to be for a DX upgrade. It shows a 1993 date but shows a version 1.0 making me suspect it is really an AX binary, though I see old posts to the contrary.
As I mentioned I have a DX model on the way, so don't know for certain what version should display to verify its version. Moreover the binary I thought was for a DX upgrade will be useless to upgrade my current CX model if it isn't a DX.
Do I have a DX binary or is some other version number reflected for a DX model?
RFI-EMI-GUY
Ok as a followup the T3011DX arrived today and upon entering test mode I got the following:
"ID 3011d 1.0 release"
So that seems to answer my questions - I think?
toolman60
RFI-EMI-GUY,
If you get a chance and can locate your info from when you ordered your KVL hirose connector would you please send me a part number for so I can chase down a couple of them. Or if anyone else knows the part number would you mind sharing it with me
RFI-EMI-GUY
RFI-EMI-GUY,
I think this is where I got my connectors. I think I used a cable for programming a Micor as the donor cable. In any event the cable chosen has to have enough conductors (5?) and you must add a resistor in the MX shell to force the radio into the keyloading mode.
Wiring the Hirose was tedious due to the tiny solder cups and numbering sequence. I have attached the instructions I was given which are superb.
Pull Push 6 Pins Male Connector Plug Compatible Hirose HRS HR10A-7P-6P | eBay
  • TKN8531.pdf
