Setting up the 396T for the Tac Mobility System
From the very beginning here are the steps for the 396T:
Go to: Program System ---> Select System (Scroll down to "New System") ---> Under "Select Sys Type" Highlight MOT push "Yes"--->Scroll to 800MHz Standard push "Yes" ---> Confirm "Yes"
From here you can set the frequencies and groups you want ---> then under "Edit Sytstem Option" or "Edit Sys Option" as on the screen, there is a heading (the 6th one down when you scroll down in this menu that says "Edit Fleet Map" ---> Select "Custom" then the heading will say "Block 0" so you simply highlight and select the sizecode you desire by scrolling and hitting your "yes" button, and this will then move you on to "Block 1" and so you'll repeat the process you used in "Block 0" in selecting your sizecode again, which will take you to "Block 2"
I hope this is helpful!
Any more questions, just ask
