Tactical Public Safety Id display
Baker845
Oregon
I have Motorola APX-6000 and programming Tactical Public Safety in one zone, and everything working as it should, but when use Xts-5000 the id for TPS doesn't show on apx-6000 display, but it does on XTS-5000 when i test. I have Dispatch and Scan selected in CPS for APX to display id's, but no id being displayed. Is there a step i missed ?
SCFDCOMM
We run this on some groups of radios. Double check all settings while both codeplugs are open side by side on two monitors if you can.
Usually how I find minor overlooked errors. I couldnt suggest whats wrong w/o looking at both codeplugs
Baker845
Oregon
I will look at both side by side, i looked and didn't see issue, but i will do that .
hakwye8518
Town of Islip, NY
Make sure your using different ids. I know with mdc the apx will not display the id if its the same as what's programmed in the apx. I do not know if that trend also applies to tps but it is something to check.
edit- I just tested this and the id will not display if both radios have the same tps id. I tested using an apx6500 and 8000xe.
Rudy3145
New York
Yes, 4 for MDC. But we want to switch to TPS and we were wondering if TPS ID supported 4 digits.
hakwye8518
Town of Islip, NY
Accessed Only: When the System Type field is set to DVRS, the field range will be from 1 to 16777211. Otherwise, the field range will be from 1 to 9999999, and when the radio is model/option capable.
SCFDCOMM
Set it up like a certain city agency does, p25 for the TSB as some call it. Essentially p25 for the 7 character ID. Personality remains analog.
Baker845
Oregon
I know this is old post i started, but the ID for TPS won't decode on second APX with the different ids? I looked at them side by side, not sure what i might be missing setting wise??
carlos7801
Lawrence MA
is TPS UI enabled for the personalities used? are they recieving Mixed and transmitting ASTRO? ensure programming of the TPS function is correct. I use this regularly with no issues, even use alias lists for TPS IDs
