Talk Groups whistler TRX-1
#1
Hi recently bought a trx-1 having worked out most of its functions apart from the talk groups i am in the uk where would i find the information to set up talk groups on my scanner i need the talk group IDs just wounded if there was so i could get the right talk group id just can't get my head round how to set up talk group thanks
kh6sz
Gulfport, Ms
#2
If you don't know the TG numbers, just add a wildcard into the talkgroup section and it will give you all talkgroups as they become active. then you can use the number it gives you and program in them separately if you want.
#3
Thanks i think that's the answer i needed luv the whistler once i get my head around the talk group thing the audio is much better then my aor dv1 so manly use the whistler to lissette to the DMR frequencies
buddrousa
NW Tenn
#4
To add to the above post if you find a TG you do not want to hear add that TG in the software LOCK IT OUT and send the data to the scanner and you will not hear that TG again using the wildcard as long as it is locked out.
#5
Talk group
when i add a wildcard asks for enter ID what do i put in ?
