TRX-1: Talkgroup Display
TexScan780D
I am monitoring a new Phase II Trunk-system with the TRX-1 and only have one talk-group program that is a Wildcard setting. I am not seeing the talk-group number which I do need to see. Is there a setting that needs to be set in the TRX-1 to see the talk-group?
When you get a hit using the Wildcard it shows the TG while it is being displayed or active. It doesn't save it, but if you turn on record on the wildcard TG you can go back to EZ Scan and look through the recordings for TG and RID info. Also, set the programming like the below.
On ADVANCED TAB in EZ Scan...
TexScan780D
Thanks. I do have the Wildcard set to record. They are using one talk-group at this time which is in the dreadful ENC. I am monitoring the conventional VHF side of the agency with one scanner and monitoring their new still in development trunk-system with the TRX-1. Therefore, when I see the scanner stop on an VHF transmission I want to see what the talk-group number is on the TRX-1.
fourwd1
Socialist state of MD
Another method - when the scan stops on the wildcard TG hit the MENU button and the first choice should be SAVE WILDCARD, hit SELECT and you can go back and see the TG number at your leisure. It will show up as the TG but no ID.
