Talkgroups in pro 96
King William, Virginia
#1
i jus dont get what and how u program talkgroups in the pro 96, i need in detail how to i kno u program DEC thinngy, the instructions confuse me, and i need someone to explain to me in a different way... thanks
mciupa
DB Administrator
Moderator
#2
Hi CPerk , I don't think it is all that difficult.
So what sort of trunking are you trying to do ?
Motorola ? EDACS?
If it is a Motorola system , make sure that you are in that mode . The should be a little M in the top left corner. For EDACS , then it will be a little E.
Press PGM then press TRUNK enter the four or five digit DEC talkgroup numbers then press enter.
Press the "UP" button to carry on. Repeat this process until your list is completly entered.
Press SCAN and you should be all set. :)
