I've been thinking about monitoring paging info. What would be a good pager for the tampa bay area? I guess it would have to be programmable and cover as many frequency ranges as possible...or can you connect a scanner to a computer and monitor pages that way?
You mean the tones that set off the bells at the stations with the voice dispatching? No, this is for alphanumeric paging which is like 1-way text messaging.
Look into a brand called Apollo Pagers. They're hand-programmable. But if you'd rather use a computer and scanner, you'll need to do a discriminator tap.
this pdw v.3.1 program picks up pocsag at 460.6 using audio connector p106 speaker-out to laptop microphone with 100% decode. doesn't seem to do the hillsborough flex in the 929's without a discriminator output, though.
Yeah. The 929-932 MHz paging uses faster buad rates and I think that's why you need a discriminator. Not sure if Pinellas is still using any GOLAY, but there might still be GOLAY pages on 460.60. Winflex (an older program) can partly decode this.
