TBIM interfacing
dcr_inc
Not an EXPERT !!
Delta, Pa
Anyone ever tie a "Non Motorola" radio into a TBIM?.. Whats involved?. Does it use TRC function and guard tones?.. Does it have E/M functionality?..
Any help would be appreciated.. I do not have specific model / part #'s to offer.. Generic question
monitor142
California
You need to clarify, a TBIM is a "Trunking Base Interface Module". That is normally in a CEB that is tied directly into a trunking system. Do you mean a standard BIM? It uses guard tone and function tone as defined in the programming in the consoles and maybe in the card itself either by programming and/or jumpers. I can't answer on the E&M for you as I have no experience whther it's onboard or an external interface.
If you are using a non-Motorola base radio and it follows the tone remote keying functionality, it should work. Worst case is you may need to add a tone remote adapter for single channel operation.
-M142
