TDMA question
Lafayette, LA
#1
If I program talkgroups into a system that are listed as TDMA in the database but I do not know the slot number will the scanner automatially discover the slot number when the talkgroup is active? I do not see a column in the database for TDMA slot. I am talking about the TX WARN system that is mixed with standard P25 digital and some phase II TDMA talkgroups. Also is there a way to change the system type after it is already created?
N0BDW
Livingston Co., NY
#2
It will, yes. The slot number is not static. It can change. As such it isn't pre-programmed.
No, but P25 Phase 1 and P25 Phase 2 systems are programmed exactly the same. There is no need to specify that the system is Phase 2 or that some TGs are TDMA.
