Technical Question
timjude
In the pines where the sun never shines
My pioneer cd player in my truck blew the mosfet output ic..Question,If i buy me an amplifier will the stereo have output Thru the rca jack's in the back of the stereo so i can use it again..Or am i SOL?...Just checking..Before i buy another cd player.
John_M
Rochester, N.Y.
Very much doubt it Tim. IC needs to be replaced if that is indeed the culprit. There should be an input signal to that IC. You may be able to route that to the output but the signal would be very low. Replace IC or buy new CD player.
ScanDaBands
Banned
State Line
John_M said:
You may also want to take it to a stereo shop and see how much they want to fix it.
Good suggestion John , but as cheap as you can get something new - might as well.
trimmerj
Pasadena, MD
If you have already determined which component has failed , would be much cheaper to repace the chip than the unit.
kb2vxa
Banned
Point Pleasant Beach, N.J.
Since you blew the output module it might be a good idea to figure out HOW you blew it before you blow another one. If I may make a suggestion, when you drive it into distortion do you think you might be overheating it? Maybe you should turn it down and save the module AND your ears?
Oh never mind, buy the biggest, baddest kicker and sub woofers you can find and give the spot welds and body joints the vibration test. I suggest you do it while stationary, if you turn into a puddle of goo it doesn't matter but if your truck falls apart on the road you'll endanger other drivers.
