Telescoping Flagpole Antenna Tower
ascott0172
Thumbing through the Harbor Freight catalog the other day I noticed they had 20 ft aluminum telescoping flagpoles on sale for 40 bucks. Needing an antenna tower or three I wondered if these could be used to mount a VHF/UHF and antenna or used as supports for an HF wire antenna.
I was considering mounting a Alpha Delta DX Ultra HF antenna between three of these and maybe using one for a scantenna and a couple of small VHF/UHF antennas.
Any reason why this wouldn't work? It seems like it would be a fairly economical solution especially when compared with crank up towers or even the tilt over pole mounts.
So is this a stupid idea or would it be practical? Is there a better solution for an economical tower to mount antennas to?
gewecke
Banned
Illinois
Good idea,as long as there isn't a lot of weight involved.
Hope it works out!
N9ZAS
zz0468
Banned
They're probably not designed to carry a huge amount of weight, but a waving flag could be a significant wind load. Is there a spec?
I think they'd do fine for wire antenna support or a single light weight antenna. It would probably hold a scantenna or something of that nature just fine. But find something else for that old Phelps Dodge Super Stormmaster! :p
ascott0172
I wouldn't think the wind loads would be any more than for a flag. No real specs as they are cheap chinese imports.
I was thinking of putting the center of the DX Ultra on a center pole and then using one for each end. Seems like it is a better idea that trying to string them between trees. I could place the flagpoles at the exact spot I want them and and right correct distance for the antenna which i can't do with trees. Being telescoping it would be easy to mount and maintain.
Buying 4 of them would be less than what one would pay for a section or two of quality tower sections.
gewecke
Banned
Illinois
Can you run a piece of steel conduit inside of it?
Just a thought here.
N9ZAS
