Television audio on a scanner
z_moonchild
Does anyone know the frequencies to hear the audio from the local TV channels?
I know that Channel 20 WDCA comes up on 511.7625,
and Channel 66 comes up on 943.1500 & 809.3625.
Sometimes Channel 4 WRC comes up on 455.8500 & 450.5500, but I think that's for their units in the field.
Thanks,
Zoom
rkorchensky
Kitchener, Ontario
Zoom,
Check this website, RadioReference. On the left side is a column called common frequencies. In there you will find all the TV channels.
Ralph
z_moonchild
Cool! Thanks
:D
the weird thing is, Channel 20 still comes up better on 511.7625.
511.7500 has more interference. Maybe it's due to my location.
Starion
West Alexandria, VA
I have NBC 4 WRC, Fox 5 WTTG, ABC 7 WJLA, CBS 9 WUSA programmed into my Yaesu VX-2R. I listen to the news during the evening and during severe weather for updates.
I should store MHz channel 50 and WETA 22 and 26 into my radio too. ;)
I also listen to NRP 88.5, CSPAN 90.1 and 97.1 WASH FM.
Bye.
SkyPager
Arnold, MD
TV stations use an offset on the audio carriers to avoid simulcasting with other stations on the same freq.
Example Ch 4 in NYC might be +10 khz while Ch 4 in DC might have no offset. There is a plan to this. I saw it once many years ago in an FCC rule book. The offset freq. steps may be diffeent for UHF 25khz or 12.5 khz. Could account for the better copy on .7625.
z_moonchild
problem on channel 20 corrected
My scanner (BC296D) is defaulted to NFM for frequencies in that range.
I switched it to WFM (like the webpage said) and Channel 20 came through clear on 511.7500. :)
Also, I didn't realize that channels 2 thru 20 were already pre-programmed into my scanner. :?
Hoseman292
39.019986,-77.01298
54.000-88.000 Mhz MHz — VHF Low Television Frequencies
59.750 - Television Audio Channel 2 (WFM)
65.750 - Television Audio Channel 3 (WFM)
71.750 - Television Audio Channel 4 (WFM)
81.750 - Television Audio Channel 5 (WFM)
87.750 - Television Audio Channel 6 (WFM)
174.000-216.000 MHz — VHF High Television Frequencies
179.750 - Television Audio Channel 7 (WFM)
185.750 - Television Audio Channel 8 (WFM)
191.750 - Television Audio Channel 9 (WFM)
197.750 - Television Audio Channel 10 (WFM)
203.750 - Television Audio Channel 11 (WFM)
209.750 - Television Audio Channel 12 (WFM)
215.750 - Television Audio Channel 13 (WFM)
470.000-806.000 MHz — UHF Television Frequencies
475.750 - Television Audio Channel 14 (WFM)
481.750 - Television Audio Channel 15 (WFM)
487.750 - Television Audio Channel 16 (WFM)
493.750 - Television Audio Channel 17 (WFM)
499.750 - Television Audio Channel 18 (WFM)
505.750 - Television Audio Channel 19 (WFM)
511.750 - Television Audio Channel 20 (WFM)
517.750 - Television Audio Channel 21 (WFM)
523.750 - Television Audio Channel 22 (WFM)
529.750 - Television Audio Channel 23 (WFM)
535.750 - Television Audio Channel 24 (WFM)
541.750 - Television Audio Channel 25 (WFM)
547.750 - Television Audio Channel 26 (WFM)
553.750 - Television Audio Channel 27 (WFM)
559.750 - Television Audio Channel 28 (WFM)
565.750 - Television Audio Channel 29 (WFM)
571.750 - Television Audio Channel 30 (WFM)
577.750 - Television Audio Channel 31 (WFM)
583.750 - Television Audio Channel 32 (WFM)
589.750 - Television Audio Channel 33 (WFM)
595.750 - Television Audio Channel 34 (WFM)
601.750 - Television Audio Channel 35 (WFM)
607.750 - Television Audio Channel 36 (WFM)
613.750 - Television Audio Channel 37 (WFM)
619.750 - Television Audio Channel 38 (WFM)
625.750 - Television Audio Channel 39 (WFM)
631.750 - Television Audio Channel 40 (WFM)
637.750 - Television Audio Channel 41 (WFM)
643.750 - Television Audio Channel 42 (WFM)
649.750 - Television Audio Channel 43 (WFM)
655.750 - Television Audio Channel 44 (WFM)
661.750 - Television Audio Channel 45 (WFM)
667.750 - Television Audio Channel 46 (WFM)
673.750 - Television Audio Channel 47 (WFM)
679.750 - Television Audio Channel 48 (WFM)
685.750 - Television Audio Channel 49 (WFM)
691.750 - Television Audio Channel 50 (WFM)
697.750 - Television Audio Channel 51 (WFM)
703.750 - Television Audio Channel 52 (WFM)
709.750 - Television Audio Channel 53 (WFM)
715.750 - Television Audio Channel 54 (WFM)
721.750 - Television Audio Channel 55 (WFM)
727.750 - Television Audio Channel 56 (WFM)
733.750 - Television Audio Channel 57 (WFM)
739.750 - Television Audio Channel 58 (WFM)
745.750 - Television Audio Channel 59 (WFM)
751.750 - Television Audio Channel 60 (WFM)
757.750 - Television Audio Channel 61 (WFM)
763.750 - Television Audio Channel 62 (WFM)
769.750 - Television Audio Channel 63 (WFM)
775.750 - Television Audio Channel 64 (WFM)
781.750 - Television Audio Channel 65 (WFM)
787.750 - Television Audio Channel 66 (WFM)
793.750 - Television Audio Channel 67 (WFM)
799.750 - Television Audio Channel 68 (WFM)
805.750 - Television Audio Channel 69 (WFM)
