telive in windows
wildbillx
Cape May, NJ
#3
Thanks just watched the video, and still not able to get it to work. I tried to follow the steps but can only get the GNUradio companion to open. If anyone gets this to work please let me know or Pm me.Thanks
#4
Cqpsk block error
Hello,
I encounter the following error when opening wintelive_10channels.grc would you have a solution?
<<< Welcome to GNU Radio Companion 3.7.10.1 >>>
Block paths:
C:\Program Files\GNURadio-3.7\share\gnuradio\grc\blocks
Loading: "C:\msys64\tetra\receiver_udp\wintelive_10channels.grc"
>>> Done
Generating: 'C:\\msys64\\tetra\\receiver_udp\\top_block.py'
Executing: C:\Program Files\GNURadio-3.7\gr-python27\python.exe -u C:\msys64\tetra\receiver_udp\top_block.py
Win32; Microsoft Visual C++ version 14.0; Boost_106000; UHD_003.009.003-0-unknown
gr-osmosdr 164a09fc (0.1.5git) gnuradio 3.7.10.1
built-in source types: file osmosdr fcd rtl rtl_tcp uhd hackrf bladerf airspy redpitaya
Using device #0 Realtek RTL2838UHIDIR SN: jenda_F_-25
Found Rafael Micro R820T tuner
[R82XX] PLL not locked!
Exact sample rate is: 2800000.037087 Hz
Traceback (most recent call last):
File "C:\msys64\tetra\receiver_udp\top_block.py", line 506, in <module>
main()
File "C:\msys64\tetra\receiver_udp\top_block.py", line 500, in main
tb = top_block_cls()
File "C:\msys64\tetra\receiver_udp\top_block.py", line 129, in __init__
self.digital_cqpsk_demod_5_3 = digital.cqpsk_demod(
AttributeError: 'module' object has no attribute 'cqpsk_demod'
>>> Done
Loading: "C:\msys64\tetra\projet landry\telive_1ch_simple_gr37_udp cqpsk brubru06.grc"
>>> Done
Generating: 'C:\\msys64\\tetra\\projet landry\\top_block.py'
Executing: C:\Program Files\GNURadio-3.7\gr-python27\python.exe -u C:\msys64\tetra\projet landry\top_block.py
Exact sample rate is: 2000000.052982 Hz
File "C:\msys64\tetra\projet landry\top_block.py", line 384, in <module>
main()
File "C:\msys64\tetra\projet landry\top_block.py", line 378, in main
File "C:\msys64\tetra\projet landry\top_block.py", line 232, in __init__
self.digital_cqpsk_demod_0 = digital.cqpsk_demod(
>>> Done
main()
>>> Done (return code 1)
main()
>>> Done
main()
Thank you for your help
