If you are using Sentinel you already have a profile backup (since your last "Read from scanner") on your computer.. Easy enough to write to new card if there is an issue with the current card...
Any SD card that does exceed the maximum supported size will work. Those high endurance cards just work better because they can tolerate more read/write cycles, thus having a long life expectancy.
