Terminals with different TEA
#1
Hello,
Is it possible to communicate (talk) with different TEAs in DMO? Like if I have TEA 1 and opposite have TEA 2 terminals. Sure they need to be set same DMO frequency, but is TEA a problem?
I believe TEA1 won't work with TEA2 in TMO mode?
Using eads radios.
If here is someone who is using eads tetra terminals, I wish you could give me tips to use.
#2
If the radios don't use SCK (Static Cypher Key) encryption it will work in DMO.
In TMO they need to be using the same TEA as the infrastructure to authenticate and encrypt (where applicable).
