Test please?
USAPatriot
PRK
Could I ask a couple of people to test my feed (link in my sig) and give me feedback on the sound?
Last night the sound inexplicably dropped out, some hiccup in WinXP's mixer, and when I got it back up, I found I can't seem to get the audio level low enough to not redline. I've got everything turned down as low as I can, but I can't hear the feed itself. So, feedback appreciated, thanks. -Rod-
kb2vxa
Banned
Point Pleasant Beach, N.J.
It sounds like at least one channel has a P25 decoding alignment problem making it sound slightly "under water", other than that it's adequate. If that's the case it may be easily corrected, mine was off a bit from the factory but a slight tweak fixed it.
USAPatriot
PRK
Thanks for the assist!
The channel that seems slightly off is probably just a very distant or blocked source. Most of the P25 traffic around here comes in at 4-6 bars. Those that come in at 3 or below get that robotic tone to them. -Rod-
Go-24
Indiana
Sounds great, do you possibly have "end code" enabled on the analog channels? Noticed the squelch swell at the close of calls. Disable that and the swell should vanish.
USAPatriot
PRK
Not that I know of, but I'm not all that savvy with the unit. It's a 796D, programmed with BC250. I'm not doing any trunking. I don't recall any setting along those lines. -Rod-
