thewraith2008
- Joined
- Nov 22, 2016
- Messages
- 1,845
Is anyone else seeing the following two errors popup using this plug-in. (Released 5th June 2018)
I notice each one of the errors listed, appear at different times.
They only seem to appear when you have the "Network Info" window open for a few hours.
Clicking 'Continue' in the error popup seems to continue on with no apparent ill affect.
I tried joining the forum where the plug-in is posted, but I've not received approval to be able to report it.
The popup window is labeled "Microsoft .NET Framework"
************** Exception Text **************
System.InvalidOperationException: Collection was modified after the enumerator was instantiated.
at System.ThrowHelper.ThrowInvalidOperationException(ExceptionResource resource)
at System.Collections.Generic.SortedSet`1.Enumerator.MoveNext()
at System.Collections.Generic.SortedDictionary`2.Enumerator.MoveNext()
at System.Linq.Enumerable.ToDictionary[TSource,TKey,TElement](IEnumerable`1 source, Func`2 keySelector, Func`2 elementSelector, IEqualityComparer`1 comparer)
at SDRSharp.Tetra.NetInfoWindow.UpdateCalls(SortedDictionary`2 calls)
at SDRSharp.Tetra.TetraPanel.TimerGui_Tick(Object sender, EventArgs e)
at System.Windows.Forms.Timer.OnTick(EventArgs e)
at System.Windows.Forms.Timer.TimerNativeWindow.WndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
System.NullReferenceException: Object reference not set to an instance of an object.
at SDRSharp.Tetra.NetInfoWindow.UpdateTextBox(List`1 rawData)
