TETRA EBTS
brzoza
Hello everyone, I'm looking for any documentation related to the Motorola TETRA EBTS base station.
I run a HAM repeater on it and I would like to have an installation and service manual.
I am also looking for an idea how to run something more than group calls on it.
Ubbe
Stockholm, Sweden
It will only handle group calls in local site trunking mode. I haven't heard that anyone, like a HAM, have managed to program a computer to connect to the E1 link and act as a controller to handle private calls, phone patches and dispatcher functions.
The EBTS series where very unreliable and modules fails frequently and Motorola did numerous hardware updates but never managed to get it under control. Hence the MBTS series where introduced 20 years ago that are super reliable.
/Ubbe
brzoza
Thank you for your response. Previously, I operated with a DMO repeater connected to the network via svxlink via a terminal with PEI interface. I missed trunking functionality. I would only be saved by the functionality of sending statuses with which I change the TG in svxlink ...
Dax50
I also have a EBTS, but without Site Controller.
@brzoza do you have information about the software updating part?
brzoza
You won't miss the SC. You need to buy on ebay or somewhere else. The radio soft is loaded when booting from SC. Additionally, the SC is a 5MHz generator for the radio. I have soft application: TSC R05.32.42 BRC R05.02.49
Dax50
Do you have a source for the SC?
I think the iDen Hardware is the same. Can you Confirm this?
If so i Need the Tetra Firmware to Flash the Iden Controller to Tetra Firmware
brzoza
The source for the SC is GPS assisted inside the SC.
iDen Hardware looks similar - it has different descriptions on the controls on the front. I will not confirm whether it is possible to upload the tetra firmware. The principle is the same - BNC ethernet and 5MHz refernce.
brzoza
This is my SC
Dax50
Do you have a Tetra Firmware an did you know the Programming process?
If i cannot get a tetra SC i will Try a iDen One.
brzoza
I have not tried to download the firmware from SC - there is no such option in the software. There is an option to transfer over tftp. I will try to test when I have such an opportunity.
There is a flash on board that has boot routines. Uploading the application to the radio and SC takes place via rs232 with the zmodem protocol.
Dax50
Interesting. I you can test tftp would be Great. Flash could be readable with a Flash Programmer. I think the Applications is saved within the files and could be saved with ftp.
