Texas New Mexico Power
dallenapd
Brazoria, Texas
SDS100 - Cant hear TXNMP. Brazoria County Conv. Freqs loaded. When Svc Type is "Utility" I get "Nothing to scan" When S/T is set to business it scans but I hear nothing.
hiegtx
Dallas, TX
When you manually loaded the frequencies, what Service Type was entered? Unless you modified it, the default, for manual entries, is Custom 1.
dallenapd
Brazoria, Texas
hiegtx
Dallas, TX
But when you added the conventional frequencies to a system, did you tag them as Utilities or Business?
As I noted, the default service type for manually entered frequencies or talkgroups is Custom 1. But, during the entry, you can change that to Utilities or Business.
William2910
Land of entrapment
Before new Mexico public service took a lot of TNMP lines, they were UHF over in NM, then went to Nextel type phones with PTT, then a app, while some had some form of 2 channel radio. Could be they are using some type of PTT app the company has.
I've noticed more going to DMR, NXDN trunked type around NM itself with the utilities.
